Re: Anvil Project and Short Intro
5. November 2014 um 15:17
It was difficult to get a good heat across the entire face in my forge, so the square horn was a little cold. I did not intend for it to be softer.
The round horn is just mild steel. It was common among old english and american anvils for the horn to be of wrought iron.
4. November 2014 um 03:03
Hello Chris,
The anvil took about 80 hours to complete. I could have done it far faster had I used a plasma cutter to cut he bevels instead of a ginder. I also could have used MIG instead of Stick to weld it all.
I designed the anvil myself and did all the work myself.
This is by no means a 'normal' project for highschool. The machining class had two levels (mixed class), one which focused on manual machining, and one which focuses more on CAD and CNC. I was the onlt one who took the manual class so the teacher asked if I had anything in mind for a project, which I did :) .
The top plate was of 4140, because of it's large cross section (3'' wide) It did not need to be tempered.
Don't worry about your English, it's very good.
Paul
26. Oktober 2014 um 00:42
Hello Everyone,
I am a 17 year old living in Canada. I first started forging roughly 2 years ago. One year ago I took a class with the American Blacksmith Brian Brazeal, where I also met Joshua McLaren, and Alec Steele. Since coming back from Mississipi I have been forging in my backyard. At this point I am searching for a dedicated forging space. Daniel Lea has introduced me to this forum.
Now that the intro is done, I can share a recent project of mine.
This was a final high school metal shop project which I began in March, and finished in September.
You can read the full writeup I did on Anvilfire through This link
I also made three videos while working on the anvil
First Anvil Making Video
Second Anvil Making Video
Last Anvil Making Video
Thanks for Reading, I look forward to seening the work of others on this forum.
